Brief Description: Started dimpling the HS skins....
This morning I started working on installing carpet on the work surface for my dimpling table. I got part way done and the stapler broke.
I just laid the carpet on top and dimpled several holes that turned out nice. The DRDT-2 worked great and was much quieter than a standard C-frame dimpler would be as you need to rap it with a hammer for each hole. Working between 4:30 and 6:00 am is not conducive to keeping friendly neighbors if you are loud.
