Brief Description: Messed around with the tool box project.
I have taken a few minutes to pound a few rivets in the tool box project. I have figured out that I can make some decent looking rivets, but need some more practice and instruction. It doesn't look much like an airplane and I have lost interest. I'll finish it up in an hour or so.
I did hang some compressed air equipment for the shop. The top unit is from right to left, air filter, pressure regulator, and air tool lubricator. The lubricator will be adjusted to put a drop of oil in the line for every minute the air is being consumed by the rivet gun, air drill, or die grinder etc.
The bottom unit does not have the lubricator and I plan to use that for the paint sprayer. I need to prime between the parts and the entire inside of the airplane and using a pneumatic spray gun is and option. Another option is to use rattle type spray cans, but that will be more expensive than a air sprayer. I haven't decided which way I will go.
