Brief Description: Match drilled all remaining holes in fuselage.
Tonight I match drilled all remaining undrilled holes in the fuselage. I also drilled with a unibit the brake, fuel, and electrical passage holes to 7/16", 5/8", and 1" respectively as called out in the plans. These holes allow the utiities to pass from the wing into the fuselage.
