Brief Description: Finished fitting tail cone assembly to aft fuse.
I continued fitting F-711 and F-712 bulkheads with the F-779 tailcone skin and WD-409 tail wheel spring mount. It was tedious, but the fit turned out good. Justine helped hold the tail wheel while I lined up the holes. I then moved on to the F-706 bulkhead before calling it a night.
