Brief Description: Start work of tail wheel mount and spring
I visited my neighbor Gerry who has built several airplanes and he was nice enough to loan me 125 3/32" clecos.
Colten finished clecoing the bottom and side skins to the aft fuselage bulkheads. I worked on drilling and fitting the WD-409 tail spring mount to F-711 and F-712 bulkheads. I also used the plans template to trim the F-779 tail cone skin. I match drilled to size D the holes for two 1/4" bolts through F-711. I still have some work on this assembly, but it is getting close.
