Garys RV-7 Builders Log
RV-7
Aileron Bell Crank install
Installed aileron bell crank after chucking up bolt in drill press to remove some material for slip fit in bushing.
Drilled out bad rivet in the L leading edge. Installed LP-4 rivets internal on L leading edge.
LP-4, LP-3 blind rivets arrived from Van's. OK to substitute per Ken Scott at Van's.
pulled rivets and bell crank bolt
Installed view of aileron bell crank
Leading edge on spar
RV-7 Home
880
Airplane and Flying
All Things Aviation
161
Family and Non-Aviat
Finishing Kit
530
Paint Related Items
Practice
Shop Set Up
187
