Riveted HS-707 to right HS skin. Blind riveted right HS-702 (front spar) to HS-707 and HS-708 (front and rear main ribs). Riveted right HS-702 to HS-706 (tip rib). Riveted right HS-702 and HS-708 to HS-601PP (skin). Clecoed rear spar assembly in place. Left off in process of riveting rear spar assembly, HS-404, HS-405 (inboard front and rear stab ribs), and HS-706 to HS-601PP skin. Using hand squeezer for the outer rivets. It's a bit of a workout but not as bad as I imagined it might be. Going to have a heck of a handshake when this is over.
Rear spar clecoed in place
Just beginning to rivet the trailing edge of the HS in this photo
