Received torque wrench today. Torqued HS-411PP center bearing nuts to 24 in-lb per torque value chart in section 5. Riveted HS-702 and HS-708 to HS-601PP on left side. Used squeezer to rivet front of HS-706 and HS-704 to HS-601PP. Out of sequence per the instructions but I see no harm in it. Next is to bring the right side to same level of rivetness. Greatly reduced smileys on 3 size rivets by setting compressor to 30 PSI and 3X gun regulator to 2. Prior smileys were at least partially due to excessive pressure.
