Brief Description: Right stab: Drilled HS-405, HS-702, HS-710, HS-714
Drilled HS-405 to HS-702 to HS-710 or HS-714 to HS-404 rib attach holes, right stabilizer. Drilled/ match drilled all remaining attach holes attaching the HS-601PP skin, right stabilizer. Removed skin and drilled outboard most holes on HS-714 and HS-710, right side.
