Brief Description: Continuing work on HS-404, HS-405, HS-601PP, HS-71
Started 12-07. Fluted and straightened HS-404 and HS-405. Followed manual steps to mark and match drill HS-404 and HS-405 to HS-601PP, HS-602 and HS-603, left side. Drilled HS-405 to HS-702 to HS-710 or HS-714 to HS-404 inboard rib attach holes on left stabilizer. Drilled/match drilled all remaining attach holes attaching 602PP skin, left side. Removed skin and drilled outboard most holes on HS-714 and HS-710, right side.
