On left stabilizer assembly, drilled HS-710, HS-714, HS-702, HS-405 and HS-404. It turns out I incorrectly marked and drilled the holes in both HS-405, so the edge distance on HS-714 was slightly less than minimum. Discussed with builder support and decided to order two new HS-405, two HS-404, HS-702, and HS-714.
