Brief Description: Left Wing - Bend and fit l leading edge skin
Finished off the leading edge rib fitting. Then cut and bent the leading edge skin from 0.025" sheet of 6061 aluminium using the vacuum forming method. Work very well again and is just as amazing the second time. Fitted the skin to the bottom of the wing. Marked out bottom spar cap rivet line and pilot drilled that through the skins and spar cap. Clecoed the skin to the bottom of the leading edge ribs. A goo days work.
