Brief Description: Right Wing - Wrapped Leading Edge
Having attached the leading edge skin to the bottom I turned the wing over and using ratchet strapes pulled the skin down on the top surface fo the ribs. Clecoed in place. Sounds easier than it was. But it turned out OK. I trimmed off an extra 5mm along the edge with hand shears. That hurts your arm cutting 12 foot cuts.
