Brief Description: Changed the cross shaft on the throttle
Having installed the Rotec TBI the throttle linkage need to work pretty hard as the TBI does not slide easilly like a butterfly throttle would. On the PAX side the cross tube would twist enough to make the throttle possition springy feeling. I change to a 12mm aluminium tube which was lighter and stringer than the composite tube I had. Still some twist but better.
