It was forecast to b a very hot day today so I decided to do the final fit of the canopy and screw it in place. Last year i had fitted it all together and drilled all the holes. So all that was needed was put it in place and screw in the screws right. Well once I got it on none of the holes lined up up. I am getting ust to this happening. One hole seemed close and I was able to get a screw in. The next hole got a bit closer and I could get th enext screw in. this process went on one hole at a time all the around the canopy until the last hole lined up. So it is done. Looks really good. Almost like an aeroplane.
