Aircraft weighing and more final checks. Will final ever be final? We used scales that came ina set of three. So we could get the aircraft wheel up on the scales all at once. Take a measurement then rotate the scales around the wheels and do it again. Take the average of each wheels measurement. Total empty weight was 360kg. That leaves 340kg for fuel and passengers. Good reason to loose weight. Not a big problem flying solo or with my wife.
Lift the tailwheel so the fuselage is level when you wiegh
