My earth journey takes flight
Zodiac CH601 XLB-TD
Re finish Rudder Surface
Removed rudder from fuselage rubbed it back with scotchbright to remove the stained primer and surface corrosion that had built up.
Rudder just off the fusealge
removed primer
removed corrosion
Zodiac CH601 XLB-TD Home
1832
Aircraft
Cockpit
515
Flight Controls
Flying :)
Inspections
Surface Finishing
Tail
Training
Wing
Wing - Flap & Ailero
