Almost done with the engine compartment.... I think. I finished the heat muff for the carb heat intake. First I had to design, cut, and trial fit everything in aluminum. Then it was disassembled and used as a pattern to duplicate each part in stainless steel. I then used stainless steel seal, blind rivets to complete the construction. Now I'll have to test it in ground test to verify the proper air flow and effectiveness. I'm already glad I have the extra engine monitoring probes... including the carb temp probe, its mounted right in the throat of the venturi where carb ice would form.
