More details... I built some custom awg 6 wires to supply power to the starter. I installed a firewall pass through lug which will not only supply the starter, but will be my main power distribution center for both sides of the firewall. I also wired up the exciter wire for the starter. In the background of the picture you can also see the voltage regulator installed on the passenger side of the firewall for the rear alternator... more wiring to follow!
