Progress!! Per the assembly manual, I successfully gapped the rings, installed them on each piston, then installed each piston into each of the six cylinders. The floating wrist pins were oiled and installed after installed the back spiral lock. I painted the exposed portions of the cyclinders with the recommended high temp engine paint as they are abou the only portion of the engine that is not alumiunum, they are steel.
