Mikes Web Site
Date:  6-8-2019
Number of Hours:  1.00
Brief Description:  Skylight seal
I installed the rubber lip seal around the sides of the roof window/skylight. The rubber seal is the same material I used to seal the bottom of the windscreen against the fuselage. I really like how it lays down, the standard ICP seal has a much more abrubt edge so I ordered this on from Aircraft Spurce instead. My list to complete my bird is starting to get pretty small!
upper window seal
upper window seal
final closure
final closure
mostly weather tight
