I installed the rubber lip seal around the sides of the roof window/skylight. The rubber seal is the same material I used to seal the bottom of the windscreen against the fuselage. I really like how it lays down, the standard ICP seal has a much more abrubt edge so I ordered this on from Aircraft Spurce instead. My list to complete my bird is starting to get pretty small!
