Mikes Web Site
Date:  10-19-2018
Number of Hours:  1.00
Brief Description:  Little things
Just another little detail. The facotry LSA has an airduct pass through on the pax side of the firewall. Since my custom engine and firewall forward application doesn't use the same hole, it had to be sealed up. So... I made a plate the appropriate size, matched the holes, primed and painted it, then put some high temp sealer on the backside and riveted the hole closed. One more step to being finished with the engine compartment.
cover plate
cover plate
