Mikes Web Site
Date:  9-14-2018
Number of Hours:  4.00
Brief Description:  Carb heat muff
It is truly amazing how much time it can take to complete a seemingly simple task! I had to fabricate a custom heat muff to supply preheated air to the carb heat side of the airbox. I built it first via trial and error in cheap aluminum, then used the pattern to build out the final form in stainless steel sheet with ss rivets as well. So far so good, I'll have to test it to make sure the air flow and heat is sufficient.
I'm glad I have a carb temp probe so I'll be able to truly verify it's effectiveness, otherwise I'd be a bit nervous :-)
aluminum mockup
aluminum mockup
SS bottom side
SS bottom side
