Michael's Sonex Project
Sonex Tri-Gear
Misc
New Air Filter
Bought a new filter to replace the one bought from Sonex. This is a K&N RU-0660 filter with the following properties:
Product Style: Round Straight Universal Air Filter
Flange Inside Diameter: 2.25 in (57 mm)
Flange Length: 0.625 in (16 mm)
Flange Offset: 0.813 in (21 mm)
Flange Type: Offset
Height: 3 in (76 mm)
Outside Diameter: 5.5 in (140 mm)
Top Style: Rubber
Top Material/Finish: None
Filter Re-Oiling Amount: 0.57 oz (17 ml)
Flanges: 1
Inner Wire: No
Weight: 1.1 lb (0.5 kg)
Filter Box
Filter Flange Side
Filter Top Side
Sonex Tri-Gear Home
1602
Canopy / Windscreen
Cowl
146
Finish Work
Flight and Tuning
106
Fuselage, Aft
59
106
Fuselage, Forward
123
252
Panel
Propeller
360
Workshop
