A new SNX-W11-03 Wing Attach Block was made after the first one was destroyed. After Cutting to shape on the Bandsaw the holes were drilled on the Drill Press. The Wing Attach Block, SNX-W11-03, was then placed on the End Attach Angle, SNX-W11-05, along with the Shim Plate, SNX-W11-04. Once place correctly the double holes were drilled out to allow the AN4-15A bolt to go through tightly.
Holes Drilled, Bolt and Nut installed but not tightened
