Michael's Sonex Project
Date:  2-3-2004
Number of Hours:  1.00
Manual Reference:  SNX-T02
Brief Description:  Working on Tail Tips Mounts
After drilling the tail tip supports, they were removed, deburred and then painted with Zinc Oxide primer. Once dried, everything was re-assembled with clecos. Two SNX-T14-04 Tail Tip Support Ribs were also attached. Everything was riveted together. Four cotter pins were also installed in the elevator hinges to capture the hinge pins.
