Michael's Sonex Project
Sonex Tri-Gear
Cowl
2-23-2008
SNX-P13
Cowl Priming
The Cowl was removed and placed outside. Two coats of sandable primer were painted on the two cowl halves after a quick sanding with 220 sandpaper.
Also the mixture control was removed. This was done so I can create a small removable panel to aid in the panel removal.
Cowl Primed
Cowl Primed
Sonex Tri-Gear Home
1602
Canopy / Windscreen
Cowl
146
Finish Work
Flight and Tuning
106
Fuselage, Aft
59
106
Fuselage, Forward
123
252
Panel
Propeller
360
Workshop
