Michael's Sonex Project
Sonex Tri-Gear
Cowl
1-16-2008
SNX-P13
Started Work on Left Cowl
Started work on the left Cowl half. The openings were cut according to the Jabiru Install manual. A notch was cut in the bottom to accommodate the nose gear. The cowling was placed on the fuselage to check early fitting. A lot of work still remains.
First Cowl Fitting
Nose Gear Notch
Sonex Tri-Gear Home
1602
Canopy / Windscreen
Cowl
146
Finish Work
Flight and Tuning
106
Fuselage, Aft
59
106
Fuselage, Forward
123
252
Panel
Propeller
360
Workshop
