Michael's Sonex Project
Date:  1-7-2008
Number of Hours:  1.50
Manual Reference:  SNX-P13
Brief Description:  Working on Prop Hub Spacer
I received two prop hub spacer tools from John Davis and the ASA. One was made for an AeroVee which I can't use. The other one was made for a Jabiru. Since I had the tools and ability to make a little nicer part, I decided to go that route. Using a router and a hole cutting tool, the new Prop Hub Spacer tool was made according to the plans. The spinner plate was used to precisely position the holes and they were up-drilled to 3/8". The six perimeter holes were drill as shown in the plane for securing the cowl.
Spacer's Provided by ASA
Newly made Spacer
Newly made Spacer
Newly made Spacer
Newly made Spacer
