Started work on installing the wing-leveler auto pilot servo. The placement under the seat was determined and the support doubler was drilled in place. The supplied pushrod was too long so I had to cut it down to the correct size, drill and tap a new hole for the push rod ends After a test fit, it was all disassembled so the parts can be primed and painted.
