Michael's Sonex Project
Date:  4-22-2007
Manual Reference:  SNX-L05
Brief Description:  Brake Handle Assembly
The parts of the brake handle assembly were primed and then re-assembled once the paint had time to dry. The protective casings for the Brake line cables were run through the new holes drilled just aft of the main landing gear. The actual cables will be run later. More parts were ordered from Wicks to help complete the brake installation.
Brake Handle Assembly, SNX-L05-04
Brake Line Hole
Brake Line Hole
