Started by putting a good coat of black paint on the top of the glareshield. Started working on connecting the Elevator control rod. Had to removed the powdercoat paint where the two pieces join. The required bolts and bushings were installed on the control rod. Rigging is still needed. The left and right rudder cables were installed and connected to the rudder horn. The cables still need to be connected to the rudders pedals.
