Brief Description: Upper and Lower Motor Mount Extrustion Work
The hole locations for the two upper motor mounts were transfered from the plans to the two parts. The holes were then drilled with a 1/8" drill bit in the drill press. The two lower motor mounts (SNX-F15-02 R/L) were traced from the plans and this shape was transferred to the 2.5" x 2.5" x 1/8" aluminum extrusion. The parts were cut to basic shape on the band saw and then filed/sanded to final shape. A little bit of finishup work is still required on these before the holes are marked and drilled.
