Michael's Sonex Project
Date:  12-19-2006
Manual Reference:  SNX-G01
Brief Description:  Fuel Tanks Straps and GlareShield ReInstallation
The four fuel tank straps, SNX-G01-08L/R and SNX-G01-09L/R, were made from 0.063 Aluminum. They were cut to shape on the bandsaw, the rough edges were removed on the belt sander, and deburred in the scotchbrite wheel. The holes were located drilled and deburred. Finally the ends were bent up at 90 degrees. The glareshiled was temporarily cleco'd back in place to check the fit of the fuel tanks. This was suggested by other builders before adding the plans indicated thickness of felt to the tank. Due to building tolerances, sometimes the felt thickness needs to be adjusted.
Four Fuel Tank Straps
Glare Shield Installed
