Brief Description: Priming Parts and SNX-SB-003 Work
The parts of the Rear Spar Carry Through were cleaned and then primed. While the primer was drying I started working on SNX-SB-003, Seat Pan support Service Bulletin. The was an optional service bulletin that Sonex Aircraft came out with. The Seat hinge attach angle, SNX-F10-03, is replaced with a 1"x1"x1/8" angle extrusion, which is much stronger then the original part. The old parts that were installed were removed by drilling out the rivets. The hinge piece was also removed by drilling out the installed rivets.
