Brief Description: Idler Support Assembly, SNX-F10-17
The Idler Support Assembly, SNX-F10-17, was constructed using parts built earlier. Two 3/16" holes were drilled for AN3 hardware, and one 7/16" hole was drilled. Two Oil Cindered bushings were installed in the 7/16" holes. The Idler plate assembly, SNX-F10-16, was installed and two temporary 3/16" bolts were installed. The correct AN hardware will be installed once the parts are primed.
