Michael's Sonex Project
Date: 5-6-2006
Number of Hours: 4.00
Manual Reference: SNX-F16
Brief Description: Continued work on SNX-F16 parts
After re-examining SNX-F16-02, Forward Tunnel Zee, it was found that two of the the three 3/8" holes wree misplaced.DAMN! A new SNX-Z05-10 part was ordered from Sonex LTD. The SNX-F16-09, Upper Forward Cross Tie, was marked on 2"x2"x1/8" angle extrusion and cut to size. The part was filed to final shape and then deburred and cleaned with a scotch-brite pad. SNX-F16-01, Lower Forward Cross Tie, was cut to rough shape from 1"x1"x1/8" angle extrusion. The holes were marked and pilot drilled. Two (right and left) Vertical Angles, SNX-F16-06R/L, were rough cut from 2.5"x2.5"x1/8" angle extrusions. The holes were marked and pilot drilled. The Support Angle, SNX-F16-04, was rough cut to shape, and the holes were marked and pilot drilled.
Making Various Parts for SNX-F16
