Brief Description: Installed Formers #2, #,3, and #4
A center line was drawn on the remaining turtle deck former flanges(#2,3 &4) SNX-F20-02, 03, and 04 Left and Right. This was used to locate through the pre drilled holes in the turtle deck skins. Each of the holes were drilled and cleco'd, starting from the top center and working down each side. The Formers were drilled and cleco'd at each of the Vertical side channels. The holes in the Former/Splice Channel Clips were drilled and clecod. This completes the Drilling and Clecoing of the Aft Fuselage.
