Brief Description: Attaching Vertical Channels to Aft Wing Skins
The Centerline of all the Vertical Channels were marked for locating throught the skin pre-drilled holes. Each channel was precisely placed and then drilled and cleco'd in place. This was done on both the left and right assembly. The lower longeron was drilled to final riveting size. The Lower and Upper splice plates (SNX-F26-05, SNX-F26-06, SNX-F26-07, SNX-F26-04) were also precisely located and drill on the left aft skin. They are currently cleco'd in place.
