The Aft Fuselage Bulkhead, SNX-F23-02, was made using 6061-T6 0.032" Aluminum. The large holes were cut using hole punches and then cleaned up with vixen files. Once the holes were drilled the part was bent into shape on the Bending Brake. The part was deburred and called complete.
