Various wiring projects were completed. First the Manifold Pressure Sensor was mounted and connected to the GRT EIS system, then the Hall Effect Current Sensor was connected to the GRT EIS system. The Serial output port from the GRT was wired. The control lines to the Flap motor were connected. and the audio input connector was finally connected to the Intercom.
