Time to install the leading edge wing lights. I am using the Duckworks light kit and the kit is very complete. The hole was marked and cut out using a Dremel cutoff wheel. The opening was cleaned up with files and deburring bits. Next the light mount plates was made and installed. The plexiglass lense mounts were started. The top mount was installed and work was started on the bottom mount.
