Started work on mounting plastic wingtip light pods to the fiberglass wingtip. Based on a recommendation of a Sonex forum member, I decided to use the Click-Bond nut plates for attaching the pods. These are attached with epoxy and not rivets which has many benefits on the fiberglass wingtips. Four holes were located on the pods and then drilled through it and the wingtip. The rivet nut plates were attached with the included expoxy and they were left to cure.
