Michael's Sonex Project
Sonex Tri-Gear
Misc
Glue Foam Together
The Green and Pink foam sections were glued together and the the front section was shaped around the cut in the green foam. There will only be a layer of pink on top of hte spar box.
Glueing Green/Pink Confor Foam
Shaping for legroom
Letting Glue Dry
Sonex Tri-Gear Home
1602
Canopy / Windscreen
Cowl
146
Finish Work
Flight and Tuning
106
Fuselage, Aft
59
106
Fuselage, Forward
123
252
Panel
Propeller
360
Workshop
