Continued working on getting the cowl to fit. Had to raise the whole Oil Cooler assembly up about 1/4" because the lower cowl was hitting the bottom of the cowl. This involved remaking a mounting bracket. A lot more trimming "here and there" trying to get the two cowl halves to meet on the bottom side. The hinge half on the bottom of the right cowl half had to be removed to get the cowl to fit correctly. The holes will have to be filled with epoxy and re-drilled.
