Finished fitting the right cowl half after many on-off-on repititions. I was really happy to see the bottom edge come into shape. Earlier in the fitting, I thought that I was going to have to add some length to the bottom edge, but it all worked out. I then started working on the hinge halfs and hinge pins needed for attaching the cowl. I luckily had enough hinge material...barely! I was worried.
