Continued wiring on the BAT/ALT switch and Starter switch. Connected power lines to the two fuse blocks and also connected the GND to the Two Fulse Blocks. Connected up the Starter Solenoid and the Alt Disconnect Solenoid. I discovered that the Continuous duty Alternator disconnect solenoid/relay was bad. Had to remove it from the installation and a new one was ordered.
