Michael's Sonex Project
Sonex Tri-Gear
SNX-P01
Oil Cooler Mounting
Two side support brackets were made based on input from Sonex and the other Builders. A Spacer was made for the bottom lip top support the side brackets. The assembly was temporarily put together and mounted on the engine.
Oil cooler Brackets
Oil Cooler Mounted, Rear
Oil Cooler Mounted, Front
Sonex Tri-Gear Home
1602
Canopy / Windscreen
Cowl
146
Finish Work
Flight and Tuning
106
Fuselage, Aft
59
106
Fuselage, Forward
123
252
Panel
Propeller
360
Workshop
