Brief Description: Throttle and Mixture Cable Routing
Decided to change the Mixture control to one that has a Vernier adjustment. The drawback is that it is a much larger knob. Should work out just fine and provide more control for the mixture. Two holes were drilled in the firewall and two large brass lamp nipples were installed to pass the throttle and mixture cables through the firewall. The openings will be filled with high temp fire stop at a later time.
